Maestro C Power Supply $64.95 Maestro C AC Power Supply This is optional and is not required when you order your Maestro C as a power supply is included with your Maestro C order. Only order this item if you require a spare power... Add to Cart
Hinge Feet for Maestro C $99.99 The tilt hinge feet option for Maestro are constructed from black anodized NC machined aluminum. The variable viewing angle is maintained by 14 in-lb constant torque hinges that do not require any... Add to Cart
Maestro C Battery Charger - Single $160.00 RRC-SMB-MBC – RRC SMBUS Mini Battery Charger Single bay battery charger for the RRC-2054-2 battery. AC power supply included Optimized charging process for RRC batteries Longer cycle life Faster... Add to Cart
Maestro C Battery $215.00 The RRC-2054-2 15V 3200mAh 48Wh Battery A reliable and high-capacity power source designed to keep your devices running smoothly. With its impressive 3200mAh capacity and 15V output, this... Add to Cart
Protective Cover for Maestro Control Console $59.99 This powder coated acrylic cover form fits to the face of your Maestro to help protect the screen and face of the unit from scratches and dust while not in use or while transporting. Fits all... Add to Cart
Maestro Control Console for FLEX-6000 and FLEX-8000 series radios $1,599.00 The FlexRadio Maestro™ — an intuitive, plug-and-play control console that directs operation of any FLEX-6000 Signature Series transceiver without need of a traditional PC. Connect Maestro directly or... Add to Cart
FlexRadio FHM-3 Hand Mic (TRS/RCA connector) $69.99 The FHM-3 hand mic incorporates a high gain, wide frequency response condenser microphone element and with its ergonomic design and a low resistance PTT button, the FHM-3 with the TRS/RCA connector... Add to Cart
