AU-510 – 500W Integrated SDR Transceiver
The AU-510 sets a new standard for integrated SDR performance, delivering a full-featured transceiver, 500W amplifier, automatic tuner, and power supply—all in one compact, high-efficiency chassis.
At its core is a revolutionary 500W transmitter module operating at up to 80% efficiency, dramatically reducing heat, power consumption, and size—making it ideal for both local and remote installations.
Designed for use with SmartSDR clients on Windows, macOS, iPad®, iPhone®, or Maestro™, the AU-510 provides flexible control with no need for a built-in front panel or display. Its headless design makes it perfect for rack-mounted stations, remote HF sites, or minimalist setups that prioritize performance and simplicity.
The AU-510 is a single SCU (Spectral Capture Unit) radio. An SCU digitizes the RF spectrum for signal processing and display, supporting up to 2 slice receivers and 2 simultaneous panadapters, covering 30 kHz to 54 MHz in real time for complete visibility and control across the bands.
Inside the AU-510:
500W high-efficiency transmitter
Integrated AC/DC power supply (80–264VAC input)
Automatic antenna tuner
SmartSignal™ adaptive predistortion for cleaner signals and reduced IMD
Controlled Envelope SSB (CESSB): Up to 3 dB more talk power with no added distortion
MultiFlex™: Enables simultaneous operation by two independent SmartSDR clients
With its fully integrated architecture, the AU-510 eliminates the need for separate amplifiers, tuners, and bulky power systems—delivering serious power and capability in a streamlined, ready-to-deploy form factor.
AU-510 Technical Specifications
General
Modes: SSB, CW, AM, SAM, FM, RTTY, Digital, and Waveforms
Frequency Coverage: Receive 30 kHz–54 MHz; Transmit on all amateur bands 160m–6m
Frequency Stability: 0.001 ppm with GNSS, 0.5 ppm with internal TCXO
Remote Operation: Built-in SmartLink™ for use with PC, Mac, iPad®, iPhone®, or Maestro™
GNSS Receiver: Integrated 12-channel GPS, Galileo, GLONASS, QZSS, SBAS
Cold Start TTFF: <35s
Optional GPSDO: 10 MHz output, stability 5×10⁻¹³ over 24 hours
Power Requirements: 80–264VAC, 35W receive, 675W transmit
Dimensions: 6.74”H × 14”W × 13.25”D (17.1 × 35.6 × 33.7 cm)
Receiver
Spectral Capture Units (SCUs): 1
Independent Band/Mode Receivers: 2
Slice Receivers: 2
Panadapters: 2 (simultaneously covering 30 kHz–54 MHz)
2 kHz RMDR: 110/115 dB
Max Spectrum Dynamic Range: >145 dB
ADC: 16-bit @ 122.88 Msps direct sampling
Spectrum Bandwidth: 5 kHz to 7 MHz
Minimum Spectrum Resolution: 5.85 Hz/pixel
Preselectors: 3rd order for amateur bands
DAX / DAX IQ Channels: 2 / 2
Receive-Only Ports: 1 base / 2 with XVTR
Transmitter
Output Power (160m–10m): 1–500W PEP, 125W AM
Output Power (6m): 1–200W PEP, 50W AM
Efficiency: Nominal 80%, peak up to 90%
Harmonic Suppression: >60 dBc
Transverter Port: 1, 100 kHz–54 MHz, adjustable up to +10 dBm
Tuner Matching Range: Up to 3:1 SWR
Adaptive Pre-distortion: Included (SmartSignal™)
Supported Modes: SSB, CW, AM, FM, Digital, and more
US Dollars
