AU-510M – 500W Integrated SDR Transceiver with Maestro Front Panel
The AU-510M redefines HF/6m operation—combining a full-featured SDR transceiver, 500W amplifier, power supply, and tuner into one compact, high-performance chassis. It’s the world’s first truly integrated 500W software-defined radio, engineered for today’s most demanding amateur radio operators.
At the core is a groundbreaking 500W transmitter module operating at up to 80% efficiency, delivering more power with less heat, lower input demands, and a dramatically lighter footprint—all within the size of a typical 100W PA system.
The AU-510M includes a built-in Maestro front panel, just like the FLEX-8600M, offering full touchscreen control, responsive knobs, and an all-in-one user experience—no PC required. Whether you're in the shack, on the road, or operating remotely, the AU-510M puts advanced SDR performance at your fingertips.
The AU-510M is a single SCU (Spectral Capture Unit) radio—ideal for most operating needs. An SCU is the part of the radio that digitizes the RF spectrum, enabling slice receivers, panadapters, and digital signal processing. A single SCU supports up to 2 slice receivers and 2 simultaneous panadapters, simultaneously covering from 30 kHz to 54 MHz, offering plenty of flexibility for everyday operating, DXing, or contesting.
Inside every AU-510M:
500W high-efficiency transmitter
Integrated power supply (80–264VAC input)
Automatic antenna tuner
SmartSignal™ adaptive predistortion for enhanced spectral purity and reduced IMD
Controlled Envelope SSB (CESSB): Up to 3 dB more talk power with reduced peak-to-average ratio—boosting signal presence without distortion
MultiFlex™: Dual-operator capability with independent SmartSDR sessions—perfect for contesting, remote ops, or shared stations
With everything built in—transmitter, tuner, amplifier, power supply, and front panel—the AU-510M eliminates bulky gear and external cabling, delivering true plug-and-play power and performance.
Ideal for remote HF projects, the AU-510M’s compact design, low heat output, and single-plug AC input make it easy to deploy in off-grid or hard-to-access locations—bringing serious power to your remote station with unmatched ease.
AU-510M Technical Specifications
General
Modes: SSB, CW, AM, SAM, FM, RTTY, Digital, and Waveforms
Coverage: All amateur bands 160m–6m (receive: 30 kHz–54 MHz)
Frequency Stability: 0.001 ppm with GNSS, 0.5 ppm with internal TCXO
Remote Operation: Built-in SmartLink™ for operation via Maestro™, iPad®, iPhone®, or PC/Mac
Integrated GNSS Receiver: 12-channel support for GPS, Galileo, GLONASS, QZSS, SBAS
Cold Start TTFF: <35s
Optional GPSDO: 10 MHz output, 5×10⁻¹³ stability over 24 hours
Power Requirements: 80–264VAC, 35W receive, 675W transmit
Dimensions: 6.74”H × 14”W × 13.25”D (17.1 × 35.6 × 33.7 cm)
Receiver
SCUs: 1 (Single Spectral Capture Unit)
Independent Band/Mode Receivers: 2
Slice Receivers: 2
Panadapters: 2 (simultaneously covering 30 kHz–54 MHz)
RMDR (2 kHz): 110/115 dB
Dynamic Range (Max Zoom): >145 dB
ADC: 16-bit, 122.88 Msps direct sampling
Spectrum Bandwidth: 5 kHz to 7 MHz
Min Resolution Bandwidth: 5.85 Hz/pixel
Preselectors: 3rd order
DAX / DAX IQ Channels: 2 / 2
Receive-Only Ports: 1 base / 2 including XVTR
Transmitter
Output Power (160m–10m): 1–500W PEP, 125W AM
Output Power (6m): 1–200W PEP, 50W AM
Efficiency: Nominal 80% (up to 90% peak efficiency)
Harmonic Suppression: >60 dBc
Transverter Support: 1 port, 100 kHz–54 MHz, adjustable up to +10 dBm
Built-In Tuner Range: Matches up to 3:1 SWR
Adaptive Pre-distortion: Included (SmartSignal™)
Modes Supported: All standard amateur modes, including digital
Display & User Interface
Integrated 8” 1920 × 1200 IPS Touchscreen
External Display Support
Built-in Maestro Interface: Instant control with knobs, buttons, and touchscreen
General
Receiver
Slice Receivers: 2
Transmitter
US Dollars
